Developers publishing application plugins need to write posts in the following format
Application Name:
price:
Author:
Features:
Supported versions:
Installation method: (It can be an installation command or a plug-in compression package (note: a zip or tar.gz format compression package))
Use tutorial:
Example: Free Nginx firewall
Application Name: Nginx Free Firewall
Price: Free
Author: 明国三年一场雨
Features: Effectively prevent common penetration attacks such as sql injection / xss / sentence Trojan
Supported versions: Centos + Ubuntu
Installation method: Import installation
Use tutorial:
First download the plugin:
Download
Select import in the panel third-party plugin
If you don't have this column now, please update to panel 6.5.1 or above.
Here are some screenshots of the features:
