AbuMoosa I can see on the demo, panel is set to work on port 80, but I can't do the same to my panel? Same goes for PHPMyadmin? Any help or advise? Thanks and Regards Muhammad
aaPanel_thisyear AbuMoosa Hello, aapanel, please set it as a non-80 port and a port not used by existing applications. Otherwise, there will be conflict. Port 80 is the web server port by default. If aapanel is set to port 80, there will be a conflict and the application will not run normally.
