cekotechnology ERR_CONNECTION_REFUSED, After upgrade panel. All website is GOOD but Cannot access aaPanel help me!!!
aaPanel_Jose cekotechnology Updating the panel will not affect the operation of the web server please send your panel login info to zhwyeah@gmail.com ,i will check it for you
Neto aaPanel_Jose I'm having the same problem, but all applications installed on Aapanel are working, but I can't access Aapanel. Error ERR_CONNECTION_REFUSED. I've already checked the Windows firewall. Does anyone have the solution?
aaP_visualcreaciones un grato saludo, me encuentro con el mismo error ERR_CONNECTION_REFUSED si me pudieran ayudar por favor, antes funcionaba correctamente pero ahora no
aaPanel_Kern aaP_visualcreaciones Hello, it is recommended to check the log of the site and check whether the A record of the domain name points to the ip of the server
aaPanel_Kern aaP_visualcreaciones Hello, the log shows that the latest is January 27, and there is no log for today. It is recommended to check what causes it, such as nginx/apache/openlitespeed not enabled? Or the domain name has expired? The A record of the domain name points incorrectly?
aaP_visualcreaciones creo que el problema esta en el dominio hice consulta y no esta apuntando correctamente esto arroja (We were unable to connect to the identified registry's RDAP server.) igualmente verificare que nginx/apache/openlitespeed esten habilitado. muy agradecida .
