satya876 PostgreSQL does not auto start after server reboot. Kindly let us know how we can add PostgeSQL service auto start from PostgreSQL Manager. Thank You !!
satya876 @aaPanel_Jose Hi, can we fix this issue. The issue is with Auto start PostgreSQL after system boot.
aaP_dariausju hello, after server restart postgresql not auto starting. need a fix again. https://prnt.sc/4CztrTJ_FLni
aaPanel_Kern aaP_dariausju Check the log interface for startup errors? Autostart is added when postgresql is installed
aaP_dariausju slow log shows only shutdown, no errors https://prnt.sc/2Mg_Ltl-4Cef do i need look another log?
aaPanel_Kern aaP_dariausju Try to use the ssh tool or terminal to log in to the root user, and execute the command to manually add the automatic startup on boot: /sbin/update-rc.d pgsql defaults
