eMominsky
You can copy the certificate file you just applied to the /www/server/panel/ssl folder
The certificate file path can be found in the site configuration
then run these command
echo “your.domain.dev” > /www/server/panel/data/domain.conf
echo “true” > /www/server/panel/data/ssl.pl
bt reload
