arsse
ok, I know your problem, let me check
When I first install nginx, and then modify the web directory to /home/jose/www, then create a site and switch to ols, I found that the directory is also /home/jose/www
You can try to create a new test website, if the directory is correct, please manually modify the wrong directory
