Hello, I would like some help from someone's support to be able to solve this problem, I have a dedicated one in which before installing the panel only with Nginx installed as I show in the print, using filezilla the sending pulled all my internet bandwidth, that is, it hit 900 and few megabytes of use and I was sending each file at more than 15 Mbps However after installing the aapanel on the same dedicated one, the sending is limited to a few mb as shown in print using the same filezilla and it doesn't use more than 100 megabytes of my connection, so I would like some help to make aapanel use more of my connection because it is limiting the sending of files both by ftp as I show in the prints and by normal sending within the panel.
DEDICATED WITH ONLY NGINX INSTALLED:
WITH AAPANEL ALREADY INSTALLED: ![](https://i.imgur.com/S5DpzyW.jpg
