aaP_gsusmarcano Hello, a few days ago I installed aapanel in an instance and put a domain that I had not yet registered and now it does not allow me to access, I would like to know if I can reinstall aapanel or do I have to delete the entire instance? Install aapanel using putty
aaPanel_Jose aaP_gsusmarcano You can execute the bt default command on the command line to check the correct login information. If you open the prompt 403 or 404, you can enter the address again
aaP_gsusmarcano hello, should I apply this command using putty as administrator?, I get the 401 error when I want to enter with the ip address that I assign automatically, that is because the domain that I put does not load because I could not register it
aaPanel_Jose aaP_gsusmarcano Getting 401 status may be that you have set authorized IP access for the panel, you can use bt command to cancel it
