aaPanel_Jose
Yes of course
requests.exceptions.SSLError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by SSLError(SSLError("bad handshake: SysCallError(-1, 'Unexpected EOF')")))
REQUEST_DATE: 2022-03-06 19:26:24
PAN_VERSION: 6.8.21
OS_VERSION: Debian GNU/Linux 11 x86_64(Py3.7.9)
REMOTE_ADDR: 192.168.1.30
REQUEST_URI: POST /plugin?action=get_soft_list
REQUEST_FORM: {'p': '1', 'type': '0', 'tojs': 'soft.get_list', 'force': '0', 'query': ''}
USER_AGENT: Mozilla/5.0 (X11; Linux x86_64; rv:97.0) Gecko/20100101 Firefox/97.0
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 485, in wrap_socket
cnx.do_handshake()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1934, in do_handshake
self.raise_ssl_error(self.ssl, result)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1664, in _raise_ssl_error
raise SysCallError(-1, "Unexpected EOF")
OpenSSL.SSL.SysCallError: (-1, 'Unexpected EOF')
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 360, in connect
ssl_context=context,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/ssl.py", line 370, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 491, in wrap_socket
raise ssl.SSLError("bad handshake: %r" % e)
ssl.SSLError: ("bad handshake: SysCallError(-1, 'Unexpected EOF')",)
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by SSLError(SSLError("bad handshake: SysCallError(-1, 'Unexpected EOF')")))
File "/www/server/panel/BTPanel/init.py", line 1578, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1526, in run
File "class/panelPlugin.py", line 685, in get_soft_list
softList = self.get_cloud_list(get)
File "class/panelPlugin.py", line 361, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 116, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 60, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 514, in send
raise SSLError(e, request=request)
Sorry, an unexpected error occurred while the panel was running. Please try to resolve this error in the following order:
1. Click the Fix button in the upper right corner of [Home], and log out of the panel and log in again.
2. Still unresolved, please take a screenshot of this window and post on the forum for help, address:https://www.aapanel.com/forum/
