When i login on panel. I'm getting this error:
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?id=43122&uuid=466250b3-85a9-45b9-affb-ad3d46b34e59&referral_code=tqWLEDOk&referral_id=0&username=alexxsalles&is_verified_email=1&email=coordenador.ti%40sudacall.com.br®_ip=177.92.105.90&last_login_ip=177.92.105.90&is_super=0&status=1&integral=0&create_time=1646397515&update_time=1646397543&email_verified_time=1646397532&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpcEFkZHJlc3MiOiIxNzcuOTIuMTA1LjkwIiwiaXNzIjoiaHR0cHM6XC9cL2JyYW5kbmV3LmFhcGFuZWwuY29tXC9hcGlcL3VzZXJcL2xvZ2luIiwiaWF0IjoxNjQ2Mzk3NjA4LCJuYmYiOjE2NDYzOTc2MDgsImp0aSI6ImNLS0JGa0dDUmpDWk9QZXUiLCJzdWIiOjQzMTIyLCJwcnYiOiIyM2JkNWM4OTQ5ZjYwMGFkYjM5ZTcwMWM0MDA4NzJkYjdhNTk3NmY3In0.MXBDyfLFGX0VwibewYP6IZkgx698inlsFC-qVWjw90Y&uid=43122&server_id=5f481688e2082f0038e017472afb0cf311d4fce479735711b1868084d660da7d&environment_info=%7B%22ip%22%3A+%22192.168.47.212%22%2C+%22is_ipv6%22%3A+0%2C+%22os%22%3A+%22Linux-5.4.0-105-generic-x86_64-with-debian-bullseye-sid%22%2C+%22mac%22%3A+%223f%3A9a%3A58%3A08%3Ad7%3A48%22%2C+%22hdid%22%3A+%228030C20F-8B69-42D5-84BA-5D805B7C3E4C%22%2C+%22ramid%22%3A+10471342080%2C+%22cpuid%22%3A+%22+0xffffffff%22%2C+%22server_name%22%3A+%22ubusdpanel.localdomain%22%2C+%22install_code%22%3A+%225f481688e2082f0038e017472afb0cf311d4fce479735711b1868084d660da7d%22%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
REQUEST_DATE: 2022-03-24 14:12:32
PAN_VERSION: 6.8.22
PAN_VERSION: 6.8.22
OS_VERSION: Ubuntu 20.04.4 LTS x86_64(Py3.7.9)
REMOTE_ADDR: 192.168.47.3
REQUEST_URI: POST /plugin?action=get_index_list
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.74 Safari/537.36 Edg/99.0.1150.46
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 175, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 72, in create_connection
File "src/gevent/event.py", line 306, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 336, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 324, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 304, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -3] Temporary failure in name resolution
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 710, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 386, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1040, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 358, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 450, in send
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 786, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 592, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?id=43122&uuid=466250b3-85a9-45b9-affb-ad3d46b34e59&referral_code=tqWLEDOk&referral_id=0&username=alexxsalles&is_verified_email=1&email=coordenador.ti%40sudacall.com.br®_ip=177.92.105.90&last_login_ip=177.92.105.90&is_super=0&status=1&integral=0&create_time=1646397515&update_time=1646397543&email_verified_time=1646397532&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpcEFkZHJlc3MiOiIxNzcuOTIuMTA1LjkwIiwiaXNzIjoiaHR0cHM6XC9cL2JyYW5kbmV3LmFhcGFuZWwuY29tXC9hcGlcL3VzZXJcL2xvZ2luIiwiaWF0IjoxNjQ2Mzk3NjA4LCJuYmYiOjE2NDYzOTc2MDgsImp0aSI6ImNLS0JGa0dDUmpDWk9QZXUiLCJzdWIiOjQzMTIyLCJwcnYiOiIyM2JkNWM4OTQ5ZjYwMGFkYjM5ZTcwMWM0MDA4NzJkYjdhNTk3NmY3In0.MXBDyfLFGX0VwibewYP6IZkgx698inlsFC-qVWjw90Y&uid=43122&server_id=5f481688e2082f0038e017472afb0cf311d4fce479735711b1868084d660da7d&environment_info=%7B%22ip%22%3A+%22192.168.47.212%22%2C+%22is_ipv6%22%3A+0%2C+%22os%22%3A+%22Linux-5.4.0-105-generic-x86_64-with-debian-bullseye-sid%22%2C+%22mac%22%3A+%223f%3A9a%3A58%3A08%3Ad7%3A48%22%2C+%22hdid%22%3A+%228030C20F-8B69-42D5-84BA-5D805B7C3E4C%22%2C+%22ramid%22%3A+10471342080%2C+%22cpuid%22%3A+%22+0xffffffff%22%2C+%22server_name%22%3A+%22ubusdpanel.localdomain%22%2C+%22install_code%22%3A+%225f481688e2082f0038e017472afb0cf311d4fce479735711b1868084d660da7d%22%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "/www/server/panel/BTPanel/init.py", line 1578, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1526, in run
File "class/panelPlugin.py", line 716, in get_index_list
softList = self.get_cloud_list(get)['list']
File "class/panelPlugin.py", line 361, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 117, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 529, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 645, in send
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 519, in send
