aaP_a_listratenkov Why it happens ? Is it possible to mount the www folder on the host? I tried, (-v /opt/aapanel:/www) But the container does not start.
aaPanel_Kern aaP_a_listratenkov Hi, your order is reversed -v /www:/opt/aapanel This is to mount /www to /opt/aapanel
aaP_a_listratenkov no, you did not understand. I want to keep the whole www folder on the host. Because with any change in the container, my settings are reset to default. Or can you tell me how to save the settings?
aaP_a_listratenkov From the example reported in the docker hub, only data about vhosts, databases and website files persists. When we restart the container, all other customizations are lost.
aaPanel_Kern aaP_a_listratenkov Hello, you can refer to the official documentation of docker https://docs.docker.com/storage/
