Taquechi
Hi, I shut down the server, have you restarted the server?
If aapanel is turned on, does it start?
Check whether the startup status: bt status
If it doesn't start, start the panel: bt start
Whether IP access is restricted, domain name is set, and SSL access is enabled
Unrestrict ip: bt 13
Cancel domain name: bt 12
Access using https://
