aaPanel_Kern dr_abbas Hello, "WebSite Speed" only supports nginx/apache, "Node Project" does not depend on nginx/apache/openlitespeed and can be used directly
dr_abbas aaPanel_Kern When we want to make a node project from the node project page it says you have to install nginx/apache and I didn't give the openlitespeed option
aaPanel_Kern dr_abbas Hello, this is a bug after testing, please leave blank in "Domain name" when building the project before fixing it, and then add it to "set"-->"Domain" after building, thank you for your feedback, we will fix it .
aaPanel_Kern dr_abbas Yes, we implement the mapping like this. Such as the mapping established by nginx/apache
dr_abbas aaPanel_Kern But I want to do mapping with openlitespeed in a node project. did you understand what I mean
aaPanel_Kern dr_abbas Hi, we are aware of this issue, please wait for us to fix it. You can use my method first.
