Hi. I'm new to all of this and need help. I have software that I need to use on my server. I uploaded the install.zip to the /www directory and unziped it. But when I go to my domain it only give me this:
"Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx.org.
Commercial support is available at nginx.com.
Thank you for using nginx.
It is supposed to showe me the installation page for my software.
I used to use Cyberpanel and unzipped the install into public_html which worked. So how can I get it to show the proper page? Is there something I should do with nginx or should I unzip it in another directory?
Your help is much appreciated.
