mohamed20 adin I had the exact same problem. The solution is to change cron time. I suggest to set the time to 00:15 Please try it and report back
aaPanel_Kern adin The time for the three tasks to be backed up to Google Drive will be separated for a longer time
adin aaPanel_Kern Why is it that when I use Log Clean, all the logs are not there even though I go to the file there is still there.
aaPanel_Kern adin Hello, this is a known issue, you can view the error log with the following command Change 7.wptest.com to your domain nginx: tail -f /www/wwwlogs/7.wptest.com.error.log apache: tail -f /www/wwwlogs/7.wptest.com-error_log
