@aaPanel_Kern @Aapanel
Plugins not able to install, tried using Ubuntu 22.04 and AlmaLinux 9.6.
Nameservers already set at 8.8.8.8 and 1.1.1.1
AAPanel version 7.0.21
This error appears if I try to install any plugin.
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 3245, in download_plugin
return json.loads(download_res.text).json()
File "/www/server/panel/pyenv/lib/python3.12/json/init__.py", line 346, in loads
return default_decoder.decode(s)
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=w(s, 0).end())
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
File "/www/server/panel/BTPanel/init.py", line 2704, in publicObject
File "/www/server/panel/BTPanel/init.py", line 2650, in run
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 536, in install_plugin
result = self.install_sync(pluginInfo,get)
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 598, in install_sync
return self.__install_plugin(pluginInfo['name'], get.version)
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 2938, in install_plugin
filename = self.download_plugin(upgrade_plugin_name, upgrade_version)
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 3250, in __download_plugin
raise public.PanelError(download_res.text)
public.exceptions.PanelError: An error occurred while the panel was running:
