thiagotgc I'm using it with nginx. Blocking with username and password works very well, but I couldn't find a way to block by IP. It's possible?
thiagotgc Thanks for the answer. But I need to release IP access to a certain address, for example: http://www.wordpress.com.br/wp-admin/ I was only able to block using Username / Password, but I would like to do the control by IP. It's possible?
aaPanel_Jose thiagotgc You can add URLs that you do not want to be accessed to the firewall's url blacklist, and then add your ip to the ip whitelist, so that you can only allow yourself to access
thiagotgc Sorry .... I didn't find Blacklist URL ... Can you please detail where I should go to block the URL and release to a single IP?
aaPanel_Jose thiagotgc There is indeed no url blacklist, I have notified the developer to deal with this problem
thiagotgc Very good!!! It would also be possible to have a field to add comments, to make it easy to identify which website is part of the rule. It would be great to be able to put IP or Name in all Firewall and Fail2Ban rules ... is it possible?
