aaP_lucassantos1540 I resized my droplet on Digital Ocean but after this my aaPanel dont open anymore. This message appear on Chrome when i try login: ERR_CONNECTION_REFUSED
aaPanel_Kern aaP_lucassantos1540 Hello, can the system enter normally now? Is aapanel running? Try to execute the following command to check /etc/init.d/bt status
aaP_lucassantos1540 aaPanel_Kern When I try to access the panel through the internal ip address, Chrome show this message: "The connection to [my ip] was refused." Typing the command appears this:
aaPanel_Kern aaP_lucassantos1540 Hello, your service does not start, can you access it when you try to start it? /etc/init.d/bt start
aaP_lucassantos1540 aaPanel_Kern It worked, thank you very much! Now when I try to access my website it shows ''502 Bad Gateway nginx'' but I think it's simpler to solve
aaPanel_Kern aaP_lucassantos1540 Hi. Is it normal to check the php service in the app store? Start it if it doesn't start
