Hi ,
Has aapanel turned on SSL ?
No
because the domain must be set before enabling the SSL feature, and after enabling a panel doesn't work !
Is your network in nat mode?
Yes, my wan network is in a NAT mode but Aapanel exited on the LAN network like Pfsense LAN network.
If aapanel-mydomain.com points to Pfsense's IP?
Yes, Aapane-mydomain.com point to the Pfsense WAN address
Does Pfsense have a route mapped to aapanel?
Yes, attached please find below the JPG file for my Firewall rule configuration
Would you please advise?
Kind regards
