Vereato Hi there guys i m getting this error on panel i install the firewall and happen this i may have any port blocked or denny
aaPanel_Kern Vereato Hi, is the problem solved? It's a network problem Unable to connect to aapanel's server. Please check /etc/resolv.conf file if nameserver is set If not please use SSH tool to set nameserver : echo "nameserver 8.8.8.8" >> /etc/resolv.conf echo "nameserver 1.1.1.1" >> /etc/resolv.conf If there are settings, please ping and curl brandnew.aapanel.com ping brandnew.aapanel.com curl -v https://brandnew.aapanel.com
jonhcarter it seems aapanel server has a limit to request to their API & it is exceeded. you can try after some time or use the fix button if there is an issue.
