Hello. I tested this case on Debian 11, ubuntu 20.4, centos7 and Fedora 36, and everyone is doing a similar error :
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
REQUEST_DATE: 2022-10-29 11:55:50
PAN_VERSION: 6.8.26
OS_VERSION: Fedora 36 (Thirty Six) x86_64(Py3.7.8)
REMOTE_ADDR: 178.131.158.47
REQUEST_URI: POST /plugin?action=get_soft_list
REQUEST_FORM: {'p': '1', 'type': '0', 'tojs': 'soft.get_list', 'force': '0', 'query': ''}
USER_AGENT: Mozilla/5.0 (X11; Linux x86_64; rv:106.0) Gecko/20100101 Firefox/106.0
`Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 175, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 73, in create_connection
File "src/gevent/event.py", line 329, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 359, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 347, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 327, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -2] Name or service not known
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 382, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1010, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 358, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -2] Name or service not known
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 574, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
File "/www/server/panel/BTPanel/init.py", line 1707, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1655, in run
File "class/panelPlugin.py", line 690, in get_soft_list
softList = self.get_cloud_list(get)
File "class/panelPlugin.py", line 366, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 117, in post
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))`
Sorry, an unexpected error occurred while the panel was running. Please try to resolve this error in the following order:
1. Click the Fix button in the upper right corner of [Home], and log out of the panel and log in again.
2. Still unresolved, please take a screenshot of this window and post on the forum for help, address:https://www.aapanel.com/forum/
After successful installation of Linux Tools, this program will not run properly!
Also, with the update of the program, neither the program will be updated nor the problem is solved!
I tried to install LAMP but it doesn't install.
I can't install apache & other lamp's softwares from the list.
Please help me.
