aaP_Wafik Hello All when i add a subdomain in settings its kicks me out of the panel and after that, I can't login again even if I try via the subdomain or IP can you help please
aaPanel_Kern aaP_Wafik Hello, try to use the command to cancel the domain name: bt 12, and then use the ip method to access the panel, and check the link of the panel: bt 14
