Hi, i have been found a soultion, and question about it, the sites can't be verified because the redirect (HTTP to HTTPS) was active, when i disabled the SSL can be renewed, so, i had this option set to off:
So, when the certificate tried to renovate, it faills, i left it on and the certificate is renewed without problem, (I know that the file verification fails to renew the ssL because of that redirect, i assume that is for that reason this option exists), but if that option remains on, the cron job turn it off the http to https then renew the certificate, but DON'T start the http to https again, and remains off, so i have to do it manually, is that a normal behaviour?? or for some reason fails to start again the http to https redirect??...i saw, but only one time that in the log, this http to https is enabled again after ssl renew, but i saw it just once....
