aaP_mdona350
Hello, do you have the data you need in the panel? If not, you can directly delete /www . nginx, mysql and other data will be deleted, pay attention to backup or make a system snapshot, and then reinstall aapanel
If it is the required data, it is recommended to check the log to solve related problems
