aaP_pokute25 i had a problem with storages , when check use command on terminal then show has not come yet 20gb storages but dashboard show 53gb , what is problem ? how to fix ?
aaPanel_Kern aaP_pokute25 Hello, use the command to view the actual situation of the hard disk. Your command only checked the /www directory, and the panel shows the / directory df -h
aaP_pokute25 aaPanel_Kern thank you very much , but i don't know how to space of disk becomes normal ?, what is the solution?
aaP_pokute25 aaPanel_Kern i found problem , it's in Recycle_bin directory, how to remove all inside this directory ?
aaPanel_Kern aaP_pokute25 Hello, you can see the file here, this is the recycle bin of the panel, check if the file is needed? It can be deleted if not needed.
