thiagotgc After upgrade, SSH Web Terminal does not work. Just keep thinking... and nothing happens... I've added several times, but nothing happens...
aaPanel_Kern thiagotgc Hi there, using the command flask-sock exists? btpip list|grep -i flask-sock If there is no manual installation: btpip install flask-sock bt restart
thiagotgc aaPanel_Kern Hi there, using the command flask-sock exists? btpip list|grep -i flask-sock If there is no manual installation: btpip install flask-sock bt restart Later... Sorted out!! Please fix it with the new update!
