You mean this log?
`230104 12:23:27 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:23:27 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:23:27 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 53637 ...
2023-01-04 12:23:27 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:23:27 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:23:27 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:23:27 0 [Note] InnoDB: Initializing buffer pool, total size = 2147483648, chunk size = 134217728
2023-01-04 12:23:27 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:23:27 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:23:27 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:23:27 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:23:27 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:23:27 0 [Note] InnoDB: 10.7.3 started; log sequence number 41367; transaction id 14
2023-01-04 12:23:27 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:23:27 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:23:27 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 12:23:27
2023-01-04 12:23:27 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 12:23:27 0 [Note] Server socket created on IP: '::'.
2023-01-04 12:23:27 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
Version: '10.7.3-MariaDB-log' socket: '/tmp/mysql.sock' port: 3306 Source distribution
2023-01-04 12:23:34 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 12:23:34 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 12:23:34 0 [Note] InnoDB: Starting shutdown...
2023-01-04 12:23:34 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 12:23:34 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 12:23:34
2023-01-04 12:23:34 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 12:23:34 0 [Note] InnoDB: Shutdown completed; log sequence number 42341; transaction id 15
2023-01-04 12:23:34 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 12:23:34 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 12:23:35 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:23:35 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:23:35 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 54286 ...
2023-01-04 12:23:35 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:23:35 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:23:35 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:23:35 0 [Note] InnoDB: Initializing buffer pool, total size = 2147483648, chunk size = 134217728
2023-01-04 12:23:35 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:23:35 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:23:35 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:23:35 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:23:35 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:23:35 0 [Note] InnoDB: 10.7.3 started; log sequence number 42341; transaction id 14
2023-01-04 12:23:35 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:23:35 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:23:35 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 12:23:35
2023-01-04 12:23:35 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 12:23:35 0 [Note] Server socket created on IP: '::'.
2023-01-04 12:23:35 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
230104 12:23:43 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:23:43 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:23:43 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 54734 ...
2023-01-04 12:23:43 0 [ERROR] mariadbd: Can't lock aria control file '/www/server/data/aria_log_control' for exclusive use, error: 11. Will retry for 30 seconds
230104 12:23:45 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:23:45 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:23:45 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 55244 ...
2023-01-04 12:23:45 0 [ERROR] mariadbd: Can't lock aria control file '/www/server/data/aria_log_control' for exclusive use, error: 11. Will retry for 30 seconds
2023-01-04 12:23:56 11 [Warning] Aborted connection 11 to db: 'unconnected' user: 'unauthenticated' host: 'v2202212175510213473.yourvserver.net' (This connection closed normally without authentication)
2023-01-04 12:24:13 0 [ERROR] mariadbd: Got error 'Could not get an exclusive lock; file is probably in use by another process' when trying to use aria control file '/www/server/data/aria_log_control'
2023-01-04 12:24:13 0 [ERROR] Plugin 'Aria' init function returned error.
2023-01-04 12:24:13 0 [ERROR] Plugin 'Aria' registration as a STORAGE ENGINE failed.
2023-01-04 12:24:13 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:24:13 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:24:13 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:24:13 0 [Note] InnoDB: Initializing buffer pool, total size = 2147483648, chunk size = 134217728
2023-01-04 12:24:13 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:24:13 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=42341,42341
2023-01-04 12:24:13 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:24:13 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 12:24:13 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:24:13 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:24:13 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:24:13 0 [Note] InnoDB: 10.7.3 started; log sequence number 42353; transaction id 14
2023-01-04 12:24:13 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:24:13 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:24:13 0 [ERROR] Could not open mysql.plugin table: "Unknown storage engine 'Aria'". Some plugins may be not loaded
2023-01-04 12:24:13 0 [ERROR] Failed to initialize plugins.
2023-01-04 12:24:13 0 [ERROR] Aborting
2023-01-04 12:24:15 0 [ERROR] mariadbd: Got error 'Could not get an exclusive lock; file is probably in use by another process' when trying to use aria control file '/www/server/data/aria_log_control'
2023-01-04 12:24:15 0 [ERROR] Plugin 'Aria' init function returned error.
2023-01-04 12:24:15 0 [ERROR] Plugin 'Aria' registration as a STORAGE ENGINE failed.
2023-01-04 12:24:15 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:24:15 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:24:15 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:24:15 0 [Note] InnoDB: Initializing buffer pool, total size = 2147483648, chunk size = 134217728
2023-01-04 12:24:15 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:24:15 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:24:15 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:24:15 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:24:15 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:24:15 0 [Note] InnoDB: 10.7.3 started; log sequence number 42365; transaction id 14
2023-01-04 12:24:15 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:24:15 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:24:15 0 [ERROR] Could not open mysql.plugin table: "Unknown storage engine 'Aria'". Some plugins may be not loaded
2023-01-04 12:24:15 0 [ERROR] Failed to initialize plugins.
2023-01-04 12:24:15 0 [ERROR] Aborting
230104 12:24:16 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
2023-01-04 12:32:12 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 12:32:12 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 12:32:12 0 [Note] InnoDB: Starting shutdown...
2023-01-04 12:32:12 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 12:32:12 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 12:32:12
2023-01-04 12:32:12 0 [Note] InnoDB: Shutdown completed; log sequence number 42513; transaction id 16
2023-01-04 12:32:12 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 12:32:25 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:32:25 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:32:25 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 1393 ...
2023-01-04 12:32:25 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:32:25 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:32:25 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:32:25 0 [Note] InnoDB: Initializing buffer pool, total size = 2147483648, chunk size = 134217728
2023-01-04 12:32:25 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:32:25 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:32:25 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:32:25 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:32:25 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:32:25 0 [Note] InnoDB: 10.7.3 started; log sequence number 42513; transaction id 14
2023-01-04 12:32:25 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:32:25 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:32:25 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 12:32:25
2023-01-04 12:32:25 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 12:32:25 0 [Note] Server socket created on IP: '::'.
2023-01-04 12:32:25 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 12:33:58 5 [Warning] Aborted connection 5 to db: 'unconnected' user: 'unauthenticated' host: 'v2202212175510213473.yourvserver.net' (This connection closed normally without authentication)
2023-01-04 12:35:19 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 12:35:19 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 12:35:19 0 [Note] InnoDB: Starting shutdown...
2023-01-04 12:35:19 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 12:35:19 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 12:35:19
2023-01-04 12:35:19 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 12:35:19 0 [Note] InnoDB: Shutdown completed; log sequence number 42525; transaction id 15
2023-01-04 12:35:19 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 12:35:19 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 12:35:20 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:35:20 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:35:20 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 2566 ...
2023-01-04 12:35:20 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:35:20 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:35:20 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:35:20 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 12:35:20 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:35:20 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:35:20 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:35:20 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:35:20 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:35:20 0 [Note] InnoDB: 10.7.3 started; log sequence number 42525; transaction id 14
2023-01-04 12:35:20 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:35:20 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:35:20 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 12:35:20
2023-01-04 12:35:20 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 12:35:20 0 [Note] Server socket created on IP: '::'.
2023-01-04 12:35:20 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 12:44:58 11 [Warning] Access denied for user 'root'@'localhost'
2023-01-04 12:45:24 15 [Warning] Access denied for user 'n5h62nkZbAcnpbWs'@'localhost'
2023-01-04 12:45:29 16 [Warning] Access denied for user 'root'@'localhost'
2023-01-04 12:46:04 9 [Warning] Aborted connection 9 to db: 'unconnected' user: 'root' host: 'localhost' (Got an error reading communication packets)
2023-01-04 12:46:04 13 [Warning] Aborted connection 13 to db: 'unconnected' user: 'root' host: 'localhost' (Got an error reading communication packets)
2023-01-04 12:46:09 17 [Warning] Access denied for user 'root'@'localhost'
Status information:
Current dir: /www/server/data/
Running threads: 0 Cached threads: 3 Stack size: 393216
Key caches:
default
Buffer_size: 536870912
Block_size: 1024
Division_limit: 100
Age_threshold: 300
Partitions: 0
blocks used: 0
not flushed: 0
w_requests: 0
writes: 0
r_requests: 0
reads: 0
handler status:
read_key: 8
read_next: 3
read_rnd 0
read_first: 8
write: 0
delete 0
update: 0
Table status:
Opened tables: 19
Open tables: 13
Open files: 32
Open streams: 4
Alarm status:
Active alarms: 0
Max used alarms: 0
Next alarm time: 0
Memory status:
Non-mmapped space allocated from system: 18931712
Number of free chunks: 81
Number of fastbin blocks: 22
Number of mmapped regions: 14
Space in mmapped regions: 398139392
Maximum total allocated space: 0
Space available in freed fastbin blocks: 1104
Total allocated space: 8204624
Total free space: 10727088
Top-most, releasable space: 25216
Estimated memory (with thread stack): 418250752
Global memory allocated by server: 377071552
Memory allocated by threads: 0
Events status:
LLA = Last Locked At LUA = Last Unlocked At
WOC = Waiting On Condition DL = Data Locked
Event scheduler status:
State : INITIALIZED
Thread id : 0
LLA : n/a:0
LUA : n/a:0
WOC : NO
Workers : 0
Executed : 0
Data locked: NO
Event queue status:
Element count : 0
Data locked : NO
Attempting lock : NO
LLA : init_queue:141
LUA : init_queue:151
WOC : NO
Next activation : never
2023-01-04 12:49:45 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 12:49:45 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 12:49:45 0 [Note] InnoDB: Starting shutdown...
2023-01-04 12:49:45 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 12:49:45 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 12:49:45
2023-01-04 12:49:46 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 12:49:46 0 [Note] InnoDB: Shutdown completed; log sequence number 42537; transaction id 15
2023-01-04 12:49:46 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 12:49:46 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 12:49:47 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 12:49:47 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 12:49:47 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 30053 ...
2023-01-04 12:49:47 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 12:49:47 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 12:49:47 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 12:49:47 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 12:49:47 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 12:49:47 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 12:49:47 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 12:49:47 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 12:49:47 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 12:49:47 0 [Note] InnoDB: 10.7.3 started; log sequence number 42537; transaction id 14
2023-01-04 12:49:47 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 12:49:47 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 12:49:47 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 12:49:47
2023-01-04 12:49:47 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 12:49:47 0 [Note] Server socket created on IP: '::'.
2023-01-04 12:49:47 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 12:49:56 5 [Warning] Access denied for user 'root'@'localhost'
2023-01-04 12:51:59 10 [Warning] Access denied for user 'root'@'localhost'
2023-01-04 12:53:40 11 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 12:53:59 13 [Warning] Access denied for user 'root'@'localhost' (using password: YES)
2023-01-04 12:54:08 8 [Warning] Aborted connection 8 to db: 'unconnected' user: 'root' host: 'localhost' (Got an error reading communication packets)
2023-01-04 12:55:52 52 [Warning] Aborted connection 52 to db: 'unconnected' user: 'root' host: 'localhost' (Got an error reading communication packets)
2023-01-04 12:55:52 54 [Warning] Aborted connection 54 to db: 'unconnected' user: 'root' host: 'localhost' (Got an error reading communication packets)
2023-01-04 12:56:36 66 [Warning] Access denied for user 'ustream'@'localhost'
2023-01-04 15:37:38 7749 [Warning] Aborted connection 7749 to db: 'unconnected' user: 'unauthenticated' host: 'v2202212175510213473.yourvserver.net' (This connection closed normally without authentication)
2023-01-04 15:48:53 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 15:48:53 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 15:48:53 0 [Note] InnoDB: Starting shutdown...
2023-01-04 15:48:53 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 15:48:53 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 15:48:53 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 15:48:53
2023-01-04 15:48:55 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 15:48:55 0 [Note] InnoDB: Shutdown completed; log sequence number 2401366580; transaction id 34179
2023-01-04 15:48:55 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 15:48:55 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 15:49:12 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 15:49:12 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 15:49:12 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 1416 ...
2023-01-04 15:49:13 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 15:49:13 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 15:49:13 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 15:49:13 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 15:49:13 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 15:49:13 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 15:49:13 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 15:49:13 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 15:49:13 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 15:49:13 0 [Note] InnoDB: 10.7.3 started; log sequence number 2401366580; transaction id 34180
2023-01-04 15:49:13 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 15:49:13 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 15:49:13 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 15:49:13 0 [Note] Server socket created on IP: '::'.
2023-01-04 15:49:13 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 15:49:13 21 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 15:49:15 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 15:49:15
2023-01-04 15:51:17 1573 [Warning] Aborted connection 1573 to db: 'unconnected' user: 'unauthenticated' host: 'v2202212175510213473.yourvserver.net' (This connection closed normally without authentication)
2023-01-04 16:02:14 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 16:02:14 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 16:02:14 0 [Note] InnoDB: Starting shutdown...
2023-01-04 16:02:14 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 16:02:14 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 16:02:14 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 16:02:14
2023-01-04 16:02:14 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 16:02:14 0 [Note] InnoDB: Shutdown completed; log sequence number 2403268781; transaction id 38177
2023-01-04 16:02:14 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 16:02:14 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 16:02:15 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 16:02:15 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 16:02:15 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 4847 ...
2023-01-04 16:02:15 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 16:02:15 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 16:02:15 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 16:02:15 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 16:02:15 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 16:02:15 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 16:02:15 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 16:02:15 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 16:02:15 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 16:02:15 0 [Note] InnoDB: 10.7.3 started; log sequence number 2403268781; transaction id 38178
2023-01-04 16:02:15 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 16:02:15 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 16:02:15 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 16:02:15 0 [Note] Server socket created on IP: '::'.
2023-01-04 16:02:15 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 16:02:16 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 16:02:16
2023-01-04 16:02:16 35 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 16:05:24 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 16:05:24 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 16:05:24 0 [Note] InnoDB: Starting shutdown...
2023-01-04 16:05:24 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 16:05:24 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 16:05:24 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 16:05:24
2023-01-04 16:05:24 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 16:05:24 0 [Note] InnoDB: Shutdown completed; log sequence number 2403843818; transaction id 39282
2023-01-04 16:05:24 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 16:05:24 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 16:05:25 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 16:05:25 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 16:05:25 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 6356 ...
2023-01-04 16:05:25 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 16:05:25 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 16:05:25 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 16:05:25 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 16:05:25 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 16:05:26 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 16:05:26 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 16:05:26 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 16:05:26 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 16:05:26 0 [Note] InnoDB: 10.7.3 started; log sequence number 2403843818; transaction id 39283
2023-01-04 16:05:26 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 16:05:26 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 16:05:26 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 16:05:26 0 [Note] Server socket created on IP: '::'.
2023-01-04 16:05:26 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 16:05:26 36 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 16:05:26 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 16:05:26
2023-01-04 16:06:05 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 16:06:05 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 16:06:05 0 [Note] InnoDB: Starting shutdown...
2023-01-04 16:06:05 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 16:06:05 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 16:06:05 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 16:06:05
2023-01-04 16:06:05 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 16:06:05 0 [Note] InnoDB: Shutdown completed; log sequence number 2403874874; transaction id 39390
2023-01-04 16:06:05 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 16:06:05 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 16:07:51 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 16:07:51 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 16:07:51 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 1481 ...
2023-01-04 16:07:51 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 16:07:51 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 16:07:51 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 16:07:51 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 16:07:51 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 16:07:51 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 16:07:51 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 16:07:51 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 16:07:51 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 16:07:51 0 [Note] InnoDB: 10.7.3 started; log sequence number 2403874874; transaction id 39391
2023-01-04 16:07:51 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 16:07:51 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 16:07:51 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 16:07:51 0 [Note] Server socket created on IP: '::'.
2023-01-04 16:07:51 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 16:07:52 30 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 16:07:54 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 16:07:54
2023-01-04 16:08:08 175 [Warning] Aborted connection 175 to db: 'unconnected' user: 'unauthenticated' host: 'v2202212175510213473.yourvserver.net' (This connection closed normally without authentication)
2023-01-04 16:12:27 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 16:12:27 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 16:12:27 0 [Note] InnoDB: Starting shutdown...
2023-01-04 16:12:27 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 16:12:27 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 16:12:27 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 16:12:27
2023-01-04 16:12:28 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 16:12:28 0 [Note] InnoDB: Shutdown completed; log sequence number 2404705379; transaction id 41169
2023-01-04 16:12:28 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 16:12:28 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 16:12:28 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 16:12:28 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 16:12:28 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 3358 ...
2023-01-04 16:12:29 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 16:12:29 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 16:12:29 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 16:12:29 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 16:12:29 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 16:12:29 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 16:12:29 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 16:12:29 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 16:12:29 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 16:12:29 0 [Note] InnoDB: 10.7.3 started; log sequence number 2404705379; transaction id 41170
2023-01-04 16:12:29 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 16:12:29 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 16:12:29 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 16:12:29 0 [Note] Server socket created on IP: '::'.
2023-01-04 16:12:29 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 16:12:29 30 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 16:12:29 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 16:12:29
2023-01-04 16:13:14 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 16:13:14 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 16:13:14 0 [Note] InnoDB: Starting shutdown...
2023-01-04 16:13:14 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 16:13:14 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 16:13:14 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 16:13:14
2023-01-04 16:13:14 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 16:13:14 0 [Note] InnoDB: Shutdown completed; log sequence number 2404910042; transaction id 41573
2023-01-04 16:13:14 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 16:13:14 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 16:13:15 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 16:13:15 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 16:13:15 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 4180 ...
2023-01-04 16:13:15 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 16:13:15 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 16:13:15 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 16:13:15 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 16:13:15 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 16:13:15 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 16:13:15 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 16:13:15 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 16:13:15 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 16:13:15 0 [Note] InnoDB: 10.7.3 started; log sequence number 2404910042; transaction id 41574
2023-01-04 16:13:15 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 16:13:15 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 16:13:15 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 16:13:15 0 [Note] Server socket created on IP: '::'.
2023-01-04 16:13:15 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 16:13:16 31 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 16:13:16 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 16:13:16
2023-01-04 16:18:27 0 [Note] /www/server/mysql/bin/mariadbd (initiated by: unknown): Normal shutdown
2023-01-04 16:18:27 0 [Note] InnoDB: FTS optimize thread exiting.
2023-01-04 16:18:27 0 [Note] InnoDB: Starting shutdown...
2023-01-04 16:18:27 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-01-04 16:18:27 0 [Note] InnoDB: Restricted to 16224 pages due to innodb_buf_pool_dump_pct=25
2023-01-04 16:18:27 0 [Note] InnoDB: Buffer pool(s) dump completed at 230104 16:18:27
2023-01-04 16:18:28 0 [Note] InnoDB: Removed temporary tablespace data file: "/www/server/data/ibtmp1"
2023-01-04 16:18:28 0 [Note] InnoDB: Shutdown completed; log sequence number 2405998239; transaction id 43807
2023-01-04 16:18:28 0 [Note] /www/server/mysql/bin/mariadbd: Shutdown complete
230104 16:18:28 mysqld_safe mysqld from pid file /www/server/data/v2202212175510213473.pid ended
230104 16:18:48 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-01-04 16:18:48 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-01-04 16:18:48 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 1480 ...
2023-01-04 16:18:48 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-01-04 16:18:48 0 [Note] InnoDB: Number of transaction pools: 1
2023-01-04 16:18:48 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-01-04 16:18:48 0 [Note] InnoDB: Initializing buffer pool, total size = 1073741824, chunk size = 134217728
2023-01-04 16:18:48 0 [Note] InnoDB: Completed initialization of buffer pool
2023-01-04 16:18:48 0 [Note] InnoDB: 128 rollback segments are active.
2023-01-04 16:18:48 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-01-04 16:18:48 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-01-04 16:18:48 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-01-04 16:18:48 0 [Note] InnoDB: 10.7.3 started; log sequence number 2405998239; transaction id 43808
2023-01-04 16:18:48 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-01-04 16:18:48 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-01-04 16:18:48 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-01-04 16:18:48 0 [Note] Server socket created on IP: '::'.
2023-01-04 16:18:48 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
2023-01-04 16:18:49 5 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-01-04 16:18:49 0 [Note] InnoDB: Buffer pool(s) load completed at 230104 16:18:49
2023-01-04 16:22:09 150 [Warning] Aborted connection 150 to db: 'unconnected' user: 'unauthenticated' host: 'v2202212175510213473.yourvserver.net' (This connection closed normally without authentication)`
