Pessoal, meu painel fica só carregando e não acessa mais...
- Estava tentando habilitar o Google Autenticador e deu certo, porém o SSL não ativou. Tentei desativar o SSL para ativar denovo e não entrou mais. Não sei mais o que fazer!
Ao verificar com o bt 22 retorna o seguinte erro:
[2025-02-27 13:24:18][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/www/server/panel/BTPanel/init.py", line 1948, in login
result = userlogin.userlogin().request_post(get)
File "/www/server/panel/class/userlogin.py", line 41, in request_post
public.chdck_salt()
File "/www/server/panel/class/public/common.py", line 3724, in chdck_salt
pdata['password'] = md5(md5(u_info['password'] + '_bt.cn') + salt)
TypeError: string indices must be integers, not 'str'
[2025-02-27 18:59:08][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/BTPanel/__init__.py", line 1948, in login
public.chdck_salt()
[2025-02-27 19:02:35][DEBUG] - Traceback (most recent call last):
public.chdck_salt()
[2025-02-27 19:05:44][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1821, in full_dispatch_request
rv = self.preprocess_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 2313, in preprocess_request
rv = self.ensure_sync(before_func)()
File "/www/server/panel/BTPanel/__init__.py", line 332, in request_check
return abort(401)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/helpers.py", line 310, in abort
current_app.aborter(code, *args, **kwargs)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/werkzeug/exceptions.py", line 864, in __call__
raise self.mapping[code](*args, **kwargs)
werkzeug.exceptions.Unauthorized: 401 Unauthorized: The server could not verify that you are authorized to access the URL requested. You either supplied the wrong credentials (e.g. a bad password), or your browser doesn't understand how to supply the credentials required.
