I am trying to access the panel from edge or Chrome, it does not allow me to open the ip, it has included https:, it tells me security problem, as I could solve the access from the browser, attached screenshot
I accessed through the root to get the ip and the encryption string at the end with this command ok
/etc/init.d/bt default
The browsers had an option that in case of doubtful ip address would allow access anyway
But now cannot
This show edge
192.xxx.xxx.xxx uses encryption to protect the information. When Microsoft Edge tried to connect to 192.xxx.xxx.xxx this time, the website sent unusual and incorrect credentials. This can happen when an attacker is trying to impersonate 192.xxx.xxx.xxx or a Wi-Fi login screen has interrupted the connection. The information is still protected because Microsoft Edge stopped the connection before any data was exchanged.
You cannot visit 192.xxx.xxx.xxx at this time because the website sent encrypted credentials that Microsoft Edge cannot process. Errors and network attacks are usually temporary, so this page will probably work later.
Thank you in advance.
Osvaldo
