aaP_paraxor4 Hello. When I want to import the database, it is not imported. The database I created is not deleted either. What is the problem?
aaPanel_Kern aaP_paraxor4 Hi, try to use phpmyadmin to check if there is a related database? Or check using the command line You can also try to add a database. Is it successful?
