Hi, I got a ddos attack yesterday. The attack stopped or made my node.js application inoperable but the panel part and my server were very fast. It only affected my node.js application. The server could not even use my network. Are special resources allocated to the node.js application? How can I give all the power of my server to the application?
my server company gave the following response:
Hello,
When we examine the traffic of your server, there does not seem to be a high usage.
Network usage appears to be at normal values.
There is no intensity in cpu, ram and network operations in your top and netstat values on the server.
Only requests via cloudflare are visible.
If the traffic of your site passes through cloudflare, we recommend that you examine the requests coming from cloudflare.
If there is an attack situation, we may also recommend that you turn on im under attack mode via cloudflare.
Best regards
My server's network or resource power is not affected, but the node.js project spontaneously stops or gives 502 while running.
