File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/core/management/base.py", line 328, in run_from_argv
self.execute(args, **cmd_options)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/core/management/base.py", line 369, in execute
output = self.handle(args, **options)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/core/management/base.py", line 83, in wrapped
res = handle_func(args, **kwargs)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/core/management/commands/makemigrations.py", line 101, in handle
loader.check_consistent_history(connection)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/migrations/loader.py", line 283, in check_consistent_history
applied = recorder.applied_migrations()
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/migrations/recorder.py", line 76, in applied_migrations
if self.has_table():
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/migrations/recorder.py", line 56, in has_table
return self.Migration.meta.db_table in self.connection.introspection.table_names(self.connection.cursor())
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/utils/asyncio.py", line 26, in inner
return func(args, **kwargs)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/backends/base/base.py", line 260, in cursor
return self.cursor()
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/backends/base/base.py", line 236, in _cursor
self.ensure_connection()
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/backends/base/base.py", line 220, in ensure_connection
self.connect()
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/utils.py", line 90, in exit
raise dj_exc_value.with_traceback(traceback) from exc_value
self.connect()
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/backends/base/base.py", line 197, in connect
self.connection = self.get_new_connection(conn_params)
return func(*args, kwargs)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/django/db/backends/postgresql/base.py", line 185, in get_new_connection
connection = Database.connect(conn_params)
File "/www/wwwroot/ContentStarzCP/CStarzCP_venv/lib/python3.8/site-packages/psycopg2/init.py", line 127, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
django.db.utils.OperationalError: FATAL: role "cs_db_user" does not exist
