Crazzyboy hello, i am facing ssl issue on my site i am using 2 servers in front i am using aapanel for reverse proxy and in 2nd server i am using it for host website i have tried multiples to fix the issue but i am not able to access wordpress dashboard
aaPanel_Kern Hello, what information is prompted for the inability to access? Do you use a CDN? Do you want to enable mandatory HTTPS? Press F12 in the browser to go to the network interface, and then visit to check for any errors. Crazzyboy
Crazzyboy Hello, Yes i am using cloudflare as cdn and yes i want to enable https mandatory <br> when i am using this setting showing this error <br> <br> i am using https for reverse proxy and getting too many redirects error on wordpress dashboard page
aaPanel_Kern Crazzyboy Hello, cloudflare redirects http to https by default At the same time, there will also be jumps inside wordpress. If it is set to http, it will prompt that there are too many redirects. Try to modify the access link of wordpress background to https
Crazzyboy Hello, When i am using https on wordpress it is showing too many redirects but when i am using http i am not able to make or edit any of my wordpress post.
Crazzyboy hello here i am not able to edit my existing published post see the error here i am using wordpress on http
