FaheemTaunsvi I have an issue with a module in the admin panel of my domain's app. Normally, it should be domain.com/app, but now it's redirecting to /app/ or public/app/, which is causing me to not be able to access the app. Can anyone help me with this?
aaPanel_Kern Hello, suggest you to check if the redirect configuration is correct? It is recommended to check the tutorial to check whether the website configuration is correct? FaheemTaunsvi
