sort: cannot read: ping.pl: No such file or directory
--2023-06-19 04:54:12-- https://node.aapanel.com/install/0/docker_install_en.sh
Length: 16976 (17K) [application/octet-stream]
Saving to: ‘docker_install_en.sh’
0K .......... ...... 100% 54.5M=0s
2023-06-19 04:54:12 (54.5 MB/s) - ‘docker_install_en.sh’ saved [16976/16976]
selecting download node...
https://download.bt.cn
{"product": "Linux panel", "setup_path": "/www/server", "openlitespeed_path": "/usr/local", "language": "English", "title": "aaPanel Linux panel", "brand": "aaPanel", "root_path": "/www", "template": "default", "logs_path": "/www/wwwlogs", "home": "https://www.aapanel.com", "recycle_bin": true}
1
curl: (23) Failure writing output to destination
chmod: cannot access '/usr/libexec/docker/cli-plugins/docker-compose': No such file or directory
Requirement already satisfied: pytz in ./pyenv/lib/python3.7/site-packages (2019.3)
[notice] A new release of pip available: 22.3 -> 23.1.2
[notice] To update, run: /www/server/panel/pyenv/bin/python3.7 -m pip install --upgrade pip
Requirement already satisfied: docker in ./pyenv/lib/python3.7/site-packages (4.2.0)
Requirement already satisfied: websocket-client>=0.32.0 in ./pyenv/lib/python3.7/site-packages (from docker) (1.2.3)
Requirement already satisfied: six>=1.4.0 in ./pyenv/lib/python3.7/site-packages (from docker) (1.16.0)
Requirement already satisfied: requests!=2.18.0,>=2.14.2 in ./pyenv/lib/python3.7/site-packages (from docker) (2.28.1)
Requirement already satisfied: certifi>=2017.4.17 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2019.11.28)
Requirement already satisfied: charset-normalizer<3,>=2 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.0.12)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (1.26.7)
Requirement already satisfied: idna<4,>=2.5 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.8)
/bin/systemctl
Warning: Stopping docker.service, but it can still be activated by:
docker.socket
Warning: The unit file, source configuration file or drop-ins of getty@tty1.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Created symlink /etc/systemd/system/getty@tty1.service → /dev/null.
Synchronizing state of docker.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable docker
