entegreturk oh well from where should I begin...
You do not have NS records over your registar
https://www.dnsinspect.com/artovva.com/10405875
This domain (I assume is the main one...) the only reason why its working its because you added the IP address in the server machine.
https://www.dnsinspect.com/serverturkiye.com/10405878
So as you can see in the 2 records DNS inspections, this issue happens exclusively because you do not have NS records on your domain names, therefore 2 options:
- Add the necessary DNS Records and wait up to 72 hours.
- Add the records on your server machine after or, experience to point the a TLD to a single IP as your Main.
If your problem persist after 72 hours, then you can rest assured its a server configuration issue, until then, you need to follow these steps if not yet done.
After that we can move on from there.
