Hi, I have a similar error.
When try to install a Python with aapanel web (button INSTALL on the Python Manager module), a error occours:
Sorry, something went wrong:
raise NotFound()
File "class/panelPlugin.py", line 1902, in a
return eval(execStr)
File "", line 1, in
File "plugin/pythonmamager/pythonmamager_main.py", line 706, in InstallPythonV
v = get.version
AttributeError: 'dict_obj' object has no attribute 'version'
I reinstall yhe Pyrhon manager and no results.
Also, I run the command (mi root directory /www):
1 retry:
/www/server/panel/pyenv/bin/pyenv install --list
-bash: /www/server/panel/pyenv/bin/pyenv: No such file or directory
2 retry:
/www/server/panel/pyenv/bin/pyvenv install --list
WARNING: the pyenv script is deprecated in favour of python3.7 -m venv
3r retry:
/www/server/panel/pyenv/bin/python install --list
/www/server/panel/pyenv/bin/python: can't find 'main' module in 'install'
