kamranhanif496
I had the same problem, and fix it by doing the following commands:
On SSH, run as root:
sed -i -e "s/www.bt.cn/console.aapanel.com/" /www/server/panel/config/config.json
sed -i -e "s/http/https/" /www/server/panel/config/config.json
bt 16
Then, access your aaPanel >> App Store and click Update App List
That done, press CTRL + R to update your browser, and that's it, everything is back to normal.
