esyede My best advice would be to just backup your database and then reinstall the postgres and redis package. I also encountered a lot of bugs after upgrading my aaPanel instance to v7.x
aaPanel_Kern yuv41 Try to use the ssh tool or terminal to log in to the root user, and execute the command to manually add the automatic startup on boot: /sbin/update-rc.d pgsql defaults /sbin/update-rc.d redis defaults
yuv41 After reinstalling PostgreSQL & Redis, and using the commands only PostreSQL starts up now, any other fixes for redis?
aaPanel_Kern Hello, is it normal to try to start using the command line? /etc/init.d/redis restart yuv41
aaP_j7game I have PostgreSQL installed on Ubuntu, but no matter what I do, the module does not start.
aaPanel_Kern Hello, is it normal to start manually? Is there a startup error log? You can also check whether there are errors in the log aaP_j7game
