aaP_haggis-jogger_0u Many apps and CMS are now compatible with both Apache and OLS. Can we also include the site's litespeed.conf file in the vhost configuration by default? include /www/wwwroot/example.com/litespeed.conf
aaPanel_Kern Hello, thank you for your suggestion. We will not consider supporting it at the moment. It is recommended that you add it manually first. aaP_haggis-jogger_0u
