aaP_ahmaddev853 Hi, I found this task in Cron Job, and I did not add it. Was it added by you or did someone hack my server? I recently added Google backup, is it related to this cron?
aaPanel_Kern aaP_ahmaddev853 Hello, sorry for your bad experience Cron tasks [Do not delete] breaking through check task security -- Brute force protection needs to be used This issue will be optimized in the next version
aaP_ahmaddev853 Hi, But you did not answer me, was it added by you, just tell me so I can be reassured
aaP_demo1 aaP_ahmaddev853 Yes, It is added by aaPanel version 7.0.8. I also see that, but this task is to prevent brute force attack on your server. Go to Security tab you will see new Brute force protection feature is enabled.
aaPanel_Kern Hello, this problem has been optimized. It is recommended that you click "FIX" on the homepage to fix it. aaP_ahmaddev853
