Hello,
I have encountered an issue with AaPanel version 7.0.10. After upgrading to this version, the Run Option for Node projects resets unexpectedly. In my case, the project’s custom start command is reverted back to the default settings. Each time I modify it and restart the project, the custom command seems to reset again.
Here are the steps I followed:
- Added a Node project using a custom run command.
- The project worked fine until I updated to version 7.0.10.
- After the update, the custom run command resets and needs to be reconfigured manually.
Please let me know if this is a known issue and if there’s a fix or workaround available.
Thank you for your assistance!
