Good evening,
I am a pro user, and I would like to address some issues that I believe concern many users.
I would like you to improve the monitoring functionality. I expected that with the pro version, I would have detailed control over which page is consuming the most CPU and RAM resources. This is very important, especially since we are talking about a website panel. Currently, I can only see the parent folder "www," which is too general.
The Statistics V2 feature does not work for me as I use LiteSpeed. Please make it compatible. I assume others are facing the same issue.
It's been a long time since I installed the panel, and the remote restore feature has not been working. I don't think it should be too difficult to fix this functionality. It would save users a lot of time if it were operational.
Please consider the above points as they are very important. This is the main reason I subscribed — to have detailed monitoring. Unfortunately, it currently does not work effectively, especially for LiteSpeed users.
