aaP_ongray111 I wanted to move few existing websites (w1.com, w2.com, ...) to a new server managed using aaPanel (with IP:1.2.3.4) I have added the websites at aaPanel, migrated the content. I need to test the websites that I have migrated to the new server (IP:1.2.3.4) managed using aaPanel. However, I have cannot updated the DNS nameserver yet, before the new sites are tested. Here is the question... How can I access the websites at aaPanel without updating nameserver (before I can update the nameserver)? I need some help urgently, thanks
aaP_habib.tipsamki aaP_ongray111 You can access you aapanel by using your server IP. You can find login credentials by execute the command bt 14, but in this command you can't see password. To change the pannel password run bt 5.
aaP_ongray111 I have no problem in accessing aaPanel. I want to access the new websites, How can I access the new websites (created at aaPanel) without updating nameserver.
aaPanel_Kern Hello, is the problem solved? You can try to use the hosts domain name to point to the IP of the server for testing. C:\Windows\System32\drivers\etc\hosts aaP_ongray111
aaPanel_Kern Hello, http://IP/aapanel-website1 http://IP/aapanel-website2 If you want to achieve access this way, you can deploy multiple websites in the site directory aaP_ongray111
aaP_ongray111 I have set-up multiple websites using aapanel (www.site1.com, www.site2.com, ...) my IP is 1.2.3.4 how to access the websites using IP (before the name-server get updated to point to the IP 1.2.3.4)
aaPanel_Kern Hello, use IP to add to the corresponding website domain, or use IP to create a website aaP_ongray111
aaP_ongray111 aaPanel_Kern I wanted to move few existing websites (w1.com, w2.com, ...) to a new server managed using aaPanel (with IP:1.2.3.4) I have added the websites at aaPanel, migrated the content. I need to test the websites that I have migrated to the new server (IP:1.2.3.4) managed using aaPanel. I want to test the newly migrated websites managed by aaPanel. How can I access the websites at aaPanel without updating nameserver (before I can update the nameserver. is there a method to access the websites similar to the method provide by CPanel, e.g. http://1.2.3.4/~website1 http://1.2.3.4/~website2
aaPanel_Kern Hello, you can add a new subdomain and point to the specified directory and then test it aaP_ongray111
