Current version:
aaPanel Stable 7.0.13
Release time: 2024-12-19
Ubuntu 24.04.1 LTS
ERR_CONNECTION_REFUSED is happening when I click "Fix" (Verify and repair the panel, continue?) and confirm. After that, I need to access the bt command in the terminal and use the option (13) Cancel IP access limit.
When I use the option (22) Display panel error log, I get the error
/www/server/panel/plugin/firewall/firewall_main.py:263: SyntaxWarning: invalid escape sequence '\d'
rep = "\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}(\/\d{1,2})?$"
/www/server/panel/plugin/firewall/firewall_main.py:665: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/plugin/firewall/firewall_main.py:997: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/plugin/firewall/firewall_main.py:1127: SyntaxWarning: invalid escape sequence '\d'
rep1 = "\d{1,5}(:\d{1,5})?$"
/www/server/panel/plugin/firewall/firewall_main.py:1137: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/plugin/firewall/firewall_main.py:1473: SyntaxWarning: invalid escape sequence '\d'
rep = "\d{1,5}(:\d{1,5})?$"
[2025-01-09 22:26:30][DEBUG] - Creating ipset aapanel.ipv4.whitelist
[2025-01-09 22:26:30][DEBUG] - Creating ipset aapanel.ipv4.blacklist
[2025-01-09 22:46:18][DEBUG] - message sent successfully!
[2025-01-09 22:46:18][DEBUG] - {"do_send": true, "stop_msg": "", "push_data": {"ip": "MY SERVER IP", "is_type": "account", "username": "MY USERNAME", "login_ip": "IP NUMBER", "login_ip_area": "", "msg_list": [">Login method:account", ">Login account:MY USERNAME", ">Login IP:IP NUMBER:55030", ">Login status:<font color=#20a53a>Success</font>"]}, "check_res": false, "check_stop_on": "", "send_data": {"973bb487be6": 1}}
[2025-01-09 22:50:31][DEBUG] - Error 123:Traceback (most recent call last):
File "/www/server/panel/mod/base/msg/tg_msg.py", line 175, in send_msg
loop.run_until_complete(self.send_msg_async(bot_token, chat_id, msg))
File "/www/server/panel/pyenv/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
return future.result()
File "/www/server/panel/mod/base/msg/tg_msg.py", line 146, in send_msg_async
await bot.send_message(chat_id=chat_id, text=msg, parse_mode='MarkdownV2')
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/bot.py", line 381, in decorator
result = await func(self, *args, **kwargs) # skipcq: PYL-E1102
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/bot.py", line 807, in send_message
return await self.send_message(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/bot.py", line 559, in send_message
result = await self.post(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/_bot.py", line 469, in post
return await self.do_post(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/_bot.py", line 497, in do_post
return await request.post(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/request/baserequest.py", line 168, in post
result = await self.request_wrapper(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/telegram/request/baserequest.py", line 328, in _request_wrapper
raise BadRequest(message)
telegram.error.BadRequest: Can't parse entities: character '|' is reserved and must be escaped with the preceding '\'
[2025-01-09 22:50:34][DEBUG] - Error 123:Traceback (most recent call last):
/www/server/panel/plugin/firewall/firewall_main.py:155: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/plugin/firewall/firewall_main.py:190: SyntaxWarning: invalid escape sequence '\d'
rep2 = "\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}(\/\d{1,2})?$"
/www/server/panel/class_v2/panel_site_v2.py:6107: SyntaxWarning: invalid escape sequence '\s'
data['domains'] = ','.join(list(set(re.search("valid_referers\s+none\s+blocked\s+(.+);\n", tmp).groups()[0].split())))
/www/server/panel/class_v2/panel_site_v2.py:6109: SyntaxWarning: invalid escape sequence '\s'
data['domains'] = ','.join(list(set(re.search("valid_referers\s+(.+);\n", tmp).groups()[0].split())))
[2025-01-11 04:54:22][DEBUG] - message sent successfully!
[2025-01-11 04:54:22][DEBUG] - {"do_send": true, "stop_msg": "", "push_data": {"ip": "MY SERVER IP", "is_type": "account", "username": "MY USERNAME", "login_ip": "IP NUMBER", "login_ip_area": "", "msg_list": [">Login method:account", ">Login account:MY USERNAME", ">Login IP:IP NUMBER:28712", ">Login status:<font color=#20a53a>Success</font>"]}, "check_res": false, "check_stop_on": "", "send_data": {"973bb487be6": 1}}
[2025-01-11 04:54:31][DEBUG] - Creating ipset aapanel.ipv4.whitelist
[2025-01-11 04:54:31][DEBUG] - Creating ipset aapanel.ipv4.blacklist
