aaP_rocco.fusella Hi all, I have done an installation of aaPanel on Ubuntu Server 24 LTS and it seems to be completed without any problems. At the end of the installation it gives me the exact url to connect to the login page and the access credentials. I try to open that page but it doesn't give me anything and it times out. What can I do to verify? I have already checked the firewall ports and they are open. Thanks
aaPanel_Kern Hello, is the problem solved? Is the security group of the server provider open to the relevant ports? aaP_rocco.fusella
claudiajeronimo To acess external link, If is I have a same problem... I test another server with version 22.04 is ok Do you can try test local access, and say to us, please. ?
