Helim aaPanel Big Problem. Bangla Font Not Sopppurt .bangla font . it shows that (????????????????????) My Php Script 100% Ok . Im Tryning others Php Script But Same Problem.
aaPanel_Jose Helim I checked that the default encoding of php is utf8, there should be no problem, or you can try to modify its default encoding
JAY aaPanel_Jose if you remember i sent a mail before like this error i faced before with other language scripts are not working
aaPanel_Jose Helim Can you provide me with your project installation script to test it? JAY Yes, but the problem was not found last time
JAY aaPanel_Jose other languages script are not working on aapanel simple i have done migration from plesk to aapanel not working but another panels like free cyberpanel and cpanel they are working with out any problem . problem you need to find and fix .
