Hello, please refer to this script
https://node.aapanel.com/install/4/xsl.sh
php_version=83
echo /www/server/php/${php_version}/src/ext/xsl
cd /www/server/php/${php_version}/src/ext/xsl
/www/server/php/${php_version}/bin/phpize
./configure --with-php-config=/www/server/php/${php_version}/bin/php-config
make && make install
if [ "${php_version}" == "83" ]; then
extFile="/www/server/php/83/lib/php/extensions/no-debug-non-zts-20230831/xsl.so"
fi
if [ -f "${extFile}" ];then
echo "extension = xsl.so" >> ${php_setup_path}/etc/php.ini
fi
echo -e "extension = " ${extFile} >> /www/server/php/${php_version}/etc/php.ini
echo -e "extension = " ${extFile} >> /www/server/php/${php_version}/etc/php-cli.ini
/etc/init.d/php-fpm-${php_version} reload
vishu22007
