aaP_wrongtocorrect.sp Hi everyone, I'm experiencing 100% CPU usage on my VPS, and after checking, it seems to be caused by PM2 running a Next.js project. Even after stopping or deleting the process, it keeps coming back. Any ideas on how to fix this? Thanks in advance!
aaPanel_Kern Hello, you can use the pkill -9 command to close the corresponding process. This is usually caused by problems with the running program aaP_wrongtocorrect.sp
