professor Hey guys. I'm currently working on an automatic deployment script, and I managed to bypass frontend for everything but domain adding. Is there any documentation on how to use backend directly do add sites? My script is kinda dirty hack that works with install_soft.sh script directly and randomizes default port by using echo to bt command. However, I don't get how to add a site. Maybe some of you do.
nobody Hello, I have the same question When I add a new website in aaPanel, some files are created in the /www/ directory. I created them manually but it didn't work. If you find the answer, I would be grateful if you could share it. Thank you.
aaPanel_Kern nobody Hi, doesn't work what error does it show? The default build site directory of the panel is /www/wwwroot
